Mini Soldering Iron - Europe Standard (Shape-BC2)
Mini Soldering Iron - Europe Standard (Shape-BC2), mini soldering iron, soldering iron, iron
Note
We recommend solder iron tips and soldering iron stand for your soldering iron as below:
TS-C4 Series Solder Iron Tip For Mini Soldering Iron
TS-KU Series Solder Iron Tip For Mini Soldering Iron
TS-D24 Series Solder Iron Tip For Mini Soldering Iron
Mini Soldering Iron, is a small, lightweight, quick heating up soldering pencil for great soldering application. Temperature can be controlled accurate, stable and easy adjusted from 100 to 400 Celsius with STM32. Benefit from dual temperature and accelerated sensors, the solder can be in sleep mode and overheating warning automatically. Soldering iron tips can be replaceable for 4 types and can be programmed software.
Portable and lightweight. More convenience for soldering.
Easy temperature control
Sleep mode, which good for safety use and extend lift of soldering tips.
Alert mode, screen appears “warning” when temperature is higher than 400℃.
Solder iron tips can be changeable.
Software can be rewrote and programmed.
The power adapter accepts 100V-240V voltage input.
Specifications |
Screen |
OLED |
USB Port |
Micro USB |
Power Port |
DC5525 |
Operating Part Dimensions |
Length: 96mm, Diameter: 16.5mm |
Heating Part Dimensions |
Length: 33mm, Diameter: 5.5mm |
Weight |
33g (power adaptor not included) |
Operation Specifications |
Power |
65W |
Adjustable Temperature Range |
100℃ - 400℃ |
Temperature Stability |
±2% |
Mini Soldering Iron Operating Part x 1
Solder iron tip type-BC2 x 1
DC5525 power adaptor (Europe Standard) x 1
Earth clamps x 1
For technical support and suggestions, please visit our forum.
Dimensions | 154mm x87mm x60mm |
Weight | G.W 374g |
Mini Soldering Iron Operating Part | 1 |
Solder iron tip type-BC2 | 1 |
DC5525 power adaptor (Europe Standard) | 1 |
Earth clamps | 1 |
HSCODE | 8515110000 |
USHSCODE | 8515110000 |
UPC | 841454118367 |
EUHSCODE | 8531202090 |
COO | CHINA |
RoHS | 1 |
from order viewThis user did not leave any comments.
Great for SMD !Great iron solder for soldering small components and SMD ones.
Iron tip can be exchanged for smaller or larger ones in a snap (just a little screw to remove it !).
You can also reflash it with alternative firmware that gives lot more options of setup.
Perfect tool for hobbyists and professionals. -
the screw to remove the cover to put in the soldering pin is bald.. so i can't remove the screw.
Watch out for the screw that holds the soldering tip...it was too tight for the Allen-key to turn when I went to install the tip for the first time (1/16-inch size is a better fit than the 1.5mm key supplied)
