![Loading...](https://static-cdn.seeedstudio.com/static/version1721127985/frontend/bs_complex/bs_complex5/en_US/images/loader-1.gif)
LoNet 800L - Mini GSM&GPRS Breakout
LoNet 800L is a mini GSM module that offers 2G GSM and GPRS data
LoNet 800L is a mini GSM module that offers 2G GSM and GPRS data. It features small size and low power consumption. Twice size as a coin and the working current low to 1mA when in sleep mode. It uses a serial port communication, supports 3GPP TS 27.007, 27.005 and SIMCOM enhanced AT Commands. Also, it supports A-GPS technique that help get indoor position by the mobile network.
Works compatible with Arduino Uno, Arduino Mini, Raspberry Pi. A mini GSM antenna is came with, but an external power supply is required.
Features:
- Quad-band 850/900/1800/1900MHz
- GPRS multi-slot class12 connectivity: max. 85.6kbps (down-load/up-load)
- GPRS mobile station class B
- 3GPP TS 27.007, 27.005 and SIMCOM enhanced AT Commands
- Real Time Clock
- Power voltage 3.4V ~ 4.4V DC
- A-GPS (Assisted Global Positioning System)
- Supports 2.8V to 5.0V logic level
- Low power consumption, 1mA in sleep mode
- Compact size 23mm x 35mm x 5.6mm
- Standard SIM Card
Part List:
- 1 x LoNet 800L - Mini GSM/GPRS Breakout
- 1 x mini GSM antenna
Please visit our blog page for more information.
For any technical support and suggestions,please go to our forum.
Dimensions | 0mm x0mm x0mm |
Weight | G.W 10g |
HSCODE | 8517709000 |
USHSCODE | 8517180050 |
UPC | 841454106739 |
EUHSCODE | 8517180000 |
COO | CHINA |
RoHS | 1 |
