LED7R Module - .NET Gadgeteer Compatible
GAD12302P
This product can now be purchased at www
This product can now be purchased at www.ghielectronics.com.
The 6 Green LED's can be programmed to rotate, to blink, to alternate or to do whatever you like them to do. Can be used as indicators of level or speed. The center Red LED is also programmable and can be used to indicate some events.
Requires socket type Y.
.NET Gadgeteer compatible cable is included.
External Links
you need to download the following software to start your Gadgeteer:
- Development tool : Microsoft Visual C# Express 2010
- Micro framework: Microsoft .NET Micro Framework 4.1 SDK
- The Gadgeteer core, mainboard SDk and module driver(GHI)
You can download these tools at : http://tinyclr.com/support
Dimensions | 0mm x0mm x0mm |
Weight | G.W 4g |
