K30 DC 20000RPM DC Motor
This motor with small size and less weight, low power
This motor with small size and less weight, low power. It can output enough force to make some model like mini aircraft and robot platform.
Specification:
Diameter: 8mm
Length: 27mm
Shaft length: 6.0mm
Shaft diameter: 1mm
Nominal Voltage: 4.7V
Pperating Voltage: 2.0-5.5V
No Load Speed: 19900 r/min
No Load Current: 0.11A
At Maximum Efficiency of Torque: 0.14mN.m(1.4g.cm)
At Maximum Efficiency of Output: 0.23W
Stall Torque: 0.7mN.m(7.1g.cm)
Stall Current: 0.42A
Dimensions | 0mm x0mm x0mm |
Weight | G.W 5g |
HSCODE | 8501101000 |
ROHS | 1 |
