Intel® Edison Compute Module
The Intel® Edison development platform is bringing down barriers in the world of wearables and IoT technology.
FEATURES
Uses a 22nm Intel® SoC that includes a dual core, dual threaded Intel® Atom™ CPU at 500MHz and a 32-bit Intel® Quark™ microcontroller at 100 MHz. It supports 40 GPIOs and includes 1GB LPDDR3, 4 GB EMMC, and dual-band WiFi and BTLE on a module slightly larger than a postage stamp.
The Intel Edison module will initially support development with Arduino* and C/C++, followed by Node.JS, Python, RTOS, and Visual Programming support in the near future.
It includes a device-to-device and device-to-cloud connectivity framework to enable cross-device communication and a cloud-based, multi-tenant, time-series analytics service.
SPECIFICATION
Physica | |
Form factor | Board with 70-pin connector |
Dimensions | 32.5 x 25.0 x 3.9 mm |
Operating temperature | 0 to 40 degC |
Connector |
Hirose DF40 Series (1.5mm, 2.0mm, or 3.0mm stack height) |
Memory | |
Max Memory size | 4GB |
Memory type | DDR3, Nand Flash |
Physical add. Ext. | 32-bit |
# of DIMMs | 0 |
ECC Memory supported: | NO |
External Interfaces | |
SD Card | 1 Interface |
UART | 2 Controllers |
I2C | 2 Controllers |
SPI | 1 Controller with 2 chip selects |
I2S | 1 Controller |
GPIO | Additional 12 (with 4 capable of PWM) |
USB 2.0 | 1 OTG Controller |
Clock Output | 32 KHz, 19.2 MHz |
Major Edison Components | |
SoC | 22nm Intel SoC includes: a dual core, dual threaded Intel Atom CPU at 500MHz, and a 32-bit Intel Quark microcontroller at 100 MHz |
RAM | 1 GB LPDDR3 POP memory |
Flash Storage | 4 GB eMMC |
WiFi | Broadcom 43340 802.11 a/b/g/n |
Dual-band (2.4 and 5 GHz) | |
On board antenna or external antenna SKU configurations | |
Bluetooth | BT 4.0 |
Power | |
Input | 3.3V – 4.5V |
Output | 100ma @3.3V and 100ma @ 1.8V |
Power | Standby (No radios): 13mW |
Standby (BT 4.0): 21.5mW | |
Standby (WiFi): 35 mW | |
Firmware + Software | |
CPU OS | Yocto Linux v1.6 |
Development Environments | Arduino IDE |
Eclipse supporting: C, C++ & Python | |
Intel XDK supporting: Node.JS & HTML5 | |
MCU OS | RTOS |
Development Environments | MCU SDK and IDE |
Dimensions | 135mm x80mm x35mm |
Weight | G.W 79g |
Intel® Edison Compute Module | 1 |
HSCODE | 8543909000 |
FCC | 1 |
CE | 1 |
ROHS | 1 |
