Helical gear set (for 90 degrees transmission)
This helical gear can be used for 90 degrees of transmission
This helical gear can be used for 90 degrees of transmission. it has good wear-resistance,low niose,transmission smooth and steady.
Feature:
- good wear-resistance
- low niose
- transmission smooth and steady.
- Material:Cu+engineering plastics
Specification:
- Gear A: tooth number(Z):15, Outer diameter:18.6mm, Thickness:6mm, Inner diameter:6mm
- Gear A: tooth number(Z):10, Outer diameter:12.8mm, Thickness:6mm, Inner diameter:4mm
Dimensions | 0mm x0mm x0mm |
Weight | G.W 9g |
HSCODE | 8483409000 |
