Grove - Universal 4 Pin 20cm Unbuckled Cable (5 PCs Pack)
Compared with the Electronic Brick system, the Grove System uses only 1 type of cable, (the Electronic Brick system uses 4)
- 10+: $2.20
Compared with the Electronic Brick system, the Grove System uses only 1 type of cable, (the Electronic Brick system uses 4). These cables are compatible with all modules included in the Grove system.
5 cables are included in this pack.
We have developed more than 400 Grove modules, covering a wide range of applications that can fulfill various needs. Click to explore the Grove Sensor family and get started to Grove your Idea. For all Grove users (especially beginners), we provide you with guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your use of the product.
More information about how to choose a cable, please refer to this manual.
Dimensions | 200mm x9.6mm x4mm |
Weight | G.W 21g |
Grove - Universal 4 Pin 20cm Unbuckled Cable | 5 |
HSCODE | 8544422900 |
USHSCODE | 8544110050 |
UPC | 841454107477 |
EUHSCODE | 8544119000 |
COO | CHINA |
EU DoC | 1 |
RoHS | 1 |
UK DoC | 1 |
Documentations
Documents
from order viewIt does what is promised.
from order viewGreat product, good design.
from order viewThis user did not leave any comments.
