K
Loading...
Grove - Thermal Imaging Camera - MLX90621 BAA 16x4 IR Array with 25° FOV
The infrared thermal imaging module has a 16x4 resolution array temperature sensor (MLX90621), which can detect the temperature of the object with an accuracy of ±1°C ±3% * |To-Ta|, Where To is the measured surface temperature of the object, and Ta is the temperature of the sensor itself. The module can use the I2C protocol to obtain low-resolution images from the camera. The field of view (FOV) of this camera is 120°x25°, the temperature measurement range is -20°C~300°C, and the working temperature is that the sensor's Ta value is between -40°~85°.
fdslkjlk
fdskl
$45.00
Out of stock
  • 10+: $40.50
Product Details
Wiki & Learn
Reviews
