K
Loading...
Grove - Single-Point Infrared Thermometer - MLX90614 DCC with 35° FOV
Rating:
100 % of 100
The infrared thermomometer module has a single-point medical-grade infrared temperature sensor (MLX90641), which can detect the temperature of objects with an accuracy of ±0.2°C in the body temperature range. At room temperature, the surface temperature of the measured object can reach an accuracy of ±0.5°C in a wide range. The module can use the I2C protocol to obtain data from the camera. The field of view (FOV) of this sensor is 35°, the temperature measurement range is -70°C~380°C, and the working temperature is that the sensor's Ta value is between -40°~85°.
$20.80
Made after ordering
  • 10+: $18.80
The minimum order quantity (MOQ) is 10. Request info
Product Details
Wiki & Learn
Reviews
