Grove - Single Axis Analog Gyro
This product is retired, please consider our Grove - 3-Axis Digital Gyro as your alternative choice
This product is retired, please consider our Grove - 3-Axis Digital Gyro as your alternative choice.
The Grove – Signal Axis Analog Gyro is based on an angular velocity sensor that uses the phenomenon of Coriolis force. It can only measure the X-axis angular velocity, which is different from other 3-Axis gyro, but with a higher speed. It can be used for the position control and attitude control like the self-balanced 2WD.
- Standard Grove Interface
- Light Weight
- High Speed
- Measure X-axis Angular Velocity
For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your using of the product.
Documents
Dimensions | 0mm x0mm x0mm |
Weight | G.W 6g |
