Grove - Serial LCD
this product is replaced by Grove - LCD RGB Backlight Serial LCD Driver twig is an UART based LCD1602 display (Hitachi HD44780 or a compatible LCD)
Note
This product is EOL now, you can choose the update version Grove - LCD RGB Backlight.
Serial LCD Driver twig is an UART based LCD1602 display (Hitachi HD44780 or a compatible LCD). It can control LCD1602 only with two I/O port pins (UART Tx and Rx).The VCC and GND are the only additional pins required for operation. Conventional LCD drivers use 7-11 I/O port pins, whereas Serial LCD twig saves all these additional I/O pins. Serial LCD twig uses AT89S52 for implementing the UART Driving logic. Now has been updated to v1.0b.
- Very easy to use.
- 4-Pin Connection ( 2 I/Os and 2 Power Pins) .
- API design similar to Arduino LiquidCrystal Library.
- Module automatically returns to listening mode.
- Comes with a rich set of demo applications.
- Back light control to save power.
- Arduino/Seeeduino compatible.
For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your using of the product.
Documents
Dimensions | 0mm x0mm x0mm |
Weight | G.W 25g |
Documentations
- Schematic and Board Files
- SerialLCD Library for v1.0b and v1.1b
- github repository for SerialLCD
- NewSoftLibrary
- a small fix to v1.0b-Library for begin() not following the correct protocol
