the AI Hardware Partner
Toggle Nav
Loading...
Grove - Round Force Sensor (FSR402)
Rating:
100 % of 100
Grove - Round Force Sensor (FSR402),touch sensor,Pressure Sensor
$14.39
In stock
  • 10+: $11.50
The Grove-Round Force Sensor(FSR402) is a force sensitive module. At the end of the sensor there is a round force sensitive resistor, the resistance of which depends on pressure applied to this resistor. Simply say, the greater the pressure, the smaller the resistance. However, the output of this sensor is not strictly linear, so we do not recommend it for accurate measurements.
Note
We've Released the Grove Selection Guide and hope to help you find the Grove suit you best.
  • Analog output
  • Reliable mechanical structure
  • High durability:
    Tested to 10 Million actuations, 1kg, 4Hz / -10% average resistance change
Typical Applications
  • Automotive electronics
  • Medical Systems
  • Industrial controls
  • Robotics
  • Interactive Educational Toy
Pin Map
Dimensions 20mm x20mm x13mm
Weight G.W 9.4g
Battery Exclude
Working voltage 3.3V/5V
Force Sensitivity Range 0.2N--20N
Force Resolution Continuous (analog)
Analog output 0-650
Grove - Round Force Sensor (FSR402) 1
Grove Cable 1
HSCODE 9026900090
USHSCODE 9026104000
UPC 841454120711
EUHSCODE 9013101000
COO CHINA
  1. Documentation
    100%
    Product Quality
    100%
    from order view
    The best product
    By
1 Item
Show per page
