Grove - Oxygen Sensor (MIX8410)
Grove - Oxygen Sensor (MIX8410) is an electrochemical oxygen sensor and it can be used to test the oxygen concentration in air. Under the catalysis of the electrodes, a redox reaction occurs on the working electrode and the counter electrode, thereby generating a current. The concentration of oxygen in the air is calculated by measuring this current and referring to the oxygen concentration linear characteristic graph.
- 10+: $29.35
- High sensitivity (0.1±0.03 mA) with linear output
- High stability with <10s response time
- Environmental protection design
- Advanced anti-leakage technology which greatly reduces the probability of leakage
- Low output current for longer sensor life
In order to enhance the user experience and improve the quality of the Grove - Oxygen Sensor, we have adopted this new version of the oxygen sensor. The old version was based on the ME2-O2-Ф20 sensor and we now bring you this new version which is based on the MIX8410-O2 sensor.
The following is a comparison of the old and new versions.
Similarities | Differences |
Same Bottom pin positions | The new version adopts an advanced anti-leakage technology, which greatly reduces the probability of leakage and solves the leakage problem of the old version. |
Same physical dimensions | The output current of the new version is lower, so the electrolyte consumption is slower and the sensor life is longer. |
Same driver board | |
Same method of use |
Attention
- When in use, the maximum input voltage cannot exceed 5.5V
- This sensor needs to be preheated for 5-10 minutes before use
- Keep the sensor out of volatile solvents
- Prohibit storing and operating the sensor in an acidic or alkaline environment
Note
The sensor value only reflects the approximated trend of gas concentration in a permissible error range, it DOES NOT represent the exact gas concentration. The detection of certain components in the air usually requires a more precise and costly instrument, which can not be done with a single gas sensor. If your projects aim to obtain the gas concentration at a very precise level, then we do not recommend this gas sensor.
Applications
- Industrial monitoring
- HAVC oxygen monitoring
- Oxygen analysis meter
- Oxygen generator
One More Thing
With the SenseCAP S2110 Grove converter and S2100 data logger, you can easily turn the Grove into a LoRaWAN® sensor. Seeed not only helps you with prototyping but also offers you the possibility to expand your project with the SenseCAP series of robust industrial sensors.
Specifications
Specification | Details |
Input Voltage | 3.3/5V |
Interface | Analog |
Measurement range | 0-25% |
Maximum Overload | 30% |
Sensitivity | 0.1±0.03 mA |
Repeatability | ±2% |
Response Time | <10S |
Working Temperature Range | -20 - 50℃ |
Storage Temperature Range | 0 ~ 50˚C |
Operating Humidity Range | 15 ~ 90% RH, no-condensing |
Power on aging time | 30min |
Hardware Overview
- 1 x 101990680, Grove - Oxygen Sensor (MIX8410)
- 1 x Grove Cable
HSCODE | 9027100090 |
USHSCODE | 8543708800 |
UPC | |
EUHSCODE | 9027109000 |
COO | CHINA |
EU DoC | 1 |
RoHS | 1 |
UK DoC | 1 |
