Grove - Multichannel Gas Sensor
Three independent gas channels in one package Built with ATmega168PA Detectable gases include:Carbon monoxide (CO) , Nitrogen dioxide (NO2) , Hydrogen (H2) , Ammonia (NH3) , Methane (CH4) , etc Grove compat
- 10+: $33.00
We have updated the product to Multichannel Gas Sensor v2 with more detailed documents and more onboard sensor modules. And we offer a lower price!
Grove – Multichannel Gas sensor is an environment detecting sensor with a built-in MiCS-6814 which can detect many unhealthy gases. 3 gases can be measured simultaneously due to its three channels, so it can help you to monitor the concentration of more than one gas.
This sensor belongs to the Grove system, and you can plug it onto the Base shield and work with Arduino directly without any jumper wires. The interface is I2C, so plug it onto the I2C port of Base shield, then you can start to work on it.
Tip
We've released the Seeed Gas Sensor Selection Guide, it will help you choose the gas sensor that best suits your needs.
Three fully independent sensing elements on one package
I2C interface with programmable address
Heating power can be shut down for low power
Detectable gases: Carbon monoxide (CO), Nitrogen dioxide (NO2), Hydrogen (H2), Ammonia (NH3), Methane (CH4), etc.
One More Thing
Dimensions | 89mm x140mm x6.8mm |
Weight | G.W 10g |
Voltage | 3.1~ 5.25V |
Ripple(@Max Power) | 80~100mV |
Max Heating Power | 88mW |
Max Power | 150mW |
ADC Precision | 10Bits |
I2C Rate | 100kHz |
VIL(@I2C) | -0.5~0.99V |
VIH(@I2C) | 2.31~5.2V |
Grove – Multichannel Gas Sensor | 1 |
26AWG Grove Cable | 1 |
HSCODE | 9027900000 |
USHSCODE | 8517620090 |
UPC | 841454107910 |
COO | CHINA |
RoHS | 1 |
stockIs there an eta when this will be back in stock? I cannot get an answer from email.
