Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Grove integrated pressure sensor suite (MPX5700AP), this module adopts advanced integrated silicon pressure sensor MPX5700AP, which has the advantages of high precision, good reliability and no calibration. It is very suitable for constructing the Arduino pressure measurement system, capable of measuring air pressure in the range of 15Kpa to 700Kpa. We included a syringe and a rubber tube in the kit.
  • Wide measure range: 2.5% Maximum Error over 0° to 85°C
  • Multiple configurations: Available in Absolute, Differential and Gauge Configurations
  • Good durability: Durable Epoxy Unibody Element
  • Grove compatible interface: The product ensures "Plug and Play" and could be versatile for various applications of Grove
If you sell balloons in the park at Christmas, you may need this sensor :D
Well, let's meet this Grove - Integrated Pressure Sensor Kit (MPX5700AP), it is made for measuring air pressure in the range of 15Kpa to 700Kpa. This module is based on the advanced integrated silicon pressure sensor MPX5700AP, which has many merits such as high accuracy, good reliability, and no need for calibration.
This module is ideally suited for building your Arduino pressure measurement system. We include an injector and a rubber tube in this kit, with the help of the Grove analog connector and the Arduino Code we offered, all you need to do is plug and download, then just enjoy it.
What is Grove?
We have developed more than 400 Grove modules, covering a wide range of applications that can fulfil various needs. Click to explore the Grove Sensor family and get started to Grove your Idea. For all Grove users (especially beginners), we provide you with guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your use of the product.
Specifications
Operating Voltage3.3V/5V DC
output interfaceanalog
Measuring Range15Kpa-700Kpa
Appearance size<20*40mm
Hardware Overview
Grove - Integrated Pressure Sensor board1
20cm Grove Cable1
55cm rubber tube1
Injector1
Certification
HSCODE9026900090
USHSCODE9026208000
UPC841454122739
EUHSCODE9013101000
COOCHINA
SKU 110020248
Grove - Integrated Pressure Sensor Kit (MPX5700AP) is made for measuring pressure in the range of 15Kpa to 700Kpa, which is perfectly suitable for making your own Arduino air pressure measurement system.
USD$34.20
$38.00
Save $3.80(10%)
You may also add
