Grove - I2C UV light Sensor - VEML6070
The Grove - I2C UV Sensor(VEML6070) is an advanced ultraviolet (UV) light sensor with an I2C protocol interface and active acknowledge (ACK) feature. It detects 320-410nm light most effectively and will convert solar UV light intensity to digital data. Based on VEML6070, it has linear sensitivity to solar UV light and can easily be adjusted by an external resistor. With the Grove I2C UV light sensor, you can make your own Arduino UV meter, or add a UV measuring function to your Raspberry Pi weather station.
- 10+: $4.20
Feature
Excellent performance of UV radiation measurement even under long time outdoor solar UV exposure
High UV sensitivity and linearity, detects 320-410nm light most effectively
Excellent temperature compensation
High dynamic detection resolution
Support acknowledge feature (ACK), allows the UV sensor to send out an alert when exposed to high-level UVI
What's more, the active acknowledge (ACK) feature with threshold windows setting allows the UV sensor to send out a UVI alert message. Under a strong solar UVI condition, the smart ACK signal can be easily implemented by the software programming.
Ultraviolet (UV) is electromagnetic radiation with a wavelength from 10 nm to 400 nm, shorter than that of visible light but longer than X-rays. Long-time exposure to UV radiation can be harmful to human bodies, like sunburns or eye damage, etc. Measuring UV index can help people aware of the current UV level and take protective measures.
With the Grove I2C UV light sensor, which is compatible with Arduino as well as Rasberry Pi, you can make your own Arduino UV meter, or add a UV measuring function to your Raspberry Pi weather station.
Note
We've Released the Grove Selection Guide and hope to help you find the Grove suit you best.
Typical Applications
Solar UV indicator, UV meter
Cosmetic/outdoor sport handheld product
Consumer products
Weather station
Pin Out
Dimensions | 20mm x20mm x8mm |
Weight | G.W 4.8g |
Grove - I2C UV Sensor (VEML6070) | 1 |
Grove Cable | 1 |
HSCODE | 9031900090 |
USHSCODE | 9031808070 |
UPC | 841454121435 |
EUHSCODE | 9013101000 |
COO | CHINA |
RoHS | 1 |
Documentations
from order viewSimply Excellent !!!
