Grove - I2C Hub
I2C Hub Grove is an extension Grove module for connecting multiply I2C devices to Grove Base Shield
- 10+: $2.20
- Chainable
- 3 Grove I2C Port
- Support 3.3V System
I2C Hub Grove is an extension Grove module for connecting multiply I2C devices to Grove Base Shield. It can use with Universal 4 Pin to X2 4 Pin cable and connects up to 3 I2C devices which may cover most developing purpose. If the interface of this product is still not enough, You can take a look at Grove - 8 Channel I2C Multiplexer/I2C Hub (TCA9548A)
Application
Using more I2C devices than you otherwise have room for on your Grove platform.
Specifications
Dimensions |
40mm x20mm x15mm |
Weight |
G.W 10g |
Battery |
Exclude |
Operating voltage |
3.⅗V |
Operation Temperature |
-25℃ to +85℃ |
Grove - I2C Hub |
X1 |
HSCODE | 8473309000 |
USHSCODE | 8471410150 |
UPC | 841454108207 |
EUHSCODE | 8471707000 |
COO | CHINA |
EU DoC | 1 |
RoHS | 1 |
UK DoC | 1 |
Documentations
from order viewExcellent and perfect quality
from order viewSimply Excellent !!!
from order viewGreat for connecting multiple sensors. Usage is obvious and easy.
from order viewEasy to use
from order viewEasy to use and very good
