Grove - Heelight Sensor
- 10+: $7.60
Grove – Heelight Sensor is a smart voice sensor that can recognize up to 500 digital voice commands(Click to download the voice file). It was originally used on the Heelight – a smart colorful bulb that can be controlled by digital sound waves. With the heelight sensor, there is no need for bluetooth, wifi, or zigbee to do non-contact light control. Now we introduce this sensor into the small and neat Grove modules, allow you to realize smart control in your Arduino – based projects.
Note: Please note that this sensor can only recognize digital voice. If you need human voice recognition module, please consider the Respeaker or Grove - Speech Recognizer.
Digital Voice Recognition
Support over 500 digital voice commands
Compatible with the Grove system
Alternative Choice
If you want to use Heelight Sensor on a bread board or integrate it to your own product/PCBA, there's a better choice for you---Heelight Core.
One More Thing
Dimensions | 20mm x20mm x10mm |
Weight | G.W 7g |
Operating Voltage | DC 3.3V~5V |
Operating Current | 15mA |
Identification Range | 0.1~10m |
Angle Range | 360° |
Baud Rate | 115200 |
Serial Port Output | TTL logic level |
Grove - Heelight Sensor | 1 |
Grove cable | 1 |
HSCODE | 9031809090 |
USHSCODE | 9026104000 |
EUHSCODE | 9013101000 |
COO | CHINA |
EU DoC | 1 |
RoHS | 1 |
UK DoC | 1 |
