the AI Hardware Partner
Toggle Nav
Loading...
Grove - Green Wrapper 1*1(4 PCS pack)
Are you getting ready to start an electronic lego project? Grove – Wrapper design adopts a Half-open space which will cause no disruption for using Grove modules. And compatible with Lego and Makeblock modules. You can use it to keep your project safe.
$2.10
In stock
  • 10+: $1.60
  • Build electronic LEGO project: Provide colorful wrappers and enable mutual-connectable as Lego modules.
  • High compatibility: Compatible with Lego and Makeblock modules that will make your project adaptable and interesting.
  • Easy to Use/Replace: Flex fastener to install and replace Grove modules conveniently.
  • Safety: Half-open space, no disruption for using Grove modules. Always keep your project safe.
Grove - Wrapper mainly used to repair and protect Grove modules. Since it is designed as a Half-open space, there will be no disruption for using Grove modules. It will save you a lot of work tweaking modules, and you can showcase your projects easily. Just like presenting your product on Youtube, if you use Grove-Wrapper to present your project, it will give a clear and clean scene. The most important thing is it can expand Lego bricks, Makeblock, and more, which will add flavor to your work and adapt your project to various environments. The mechanical design of the Grove - Wrapper also makes it easy to assemble and disassemble the modules.
Here's a Lego easy project that you might want to start, It perfect fit for beginner.
In this project author, Sander Hendrickx made two tiny houses made of lego to keep in touch with long-distance relationships in a fun way. Just place your house on your desk, nightstand or anywhere else you like. The button at the top of the chimney toggles the message on the other house. It also lets other people know you're home.
Here's what you need :
AllThingsTalk IOTOPIA Rapid Development kit which have:
Grove - Wrapper
Grove - 16X2 LCD RGB Backlight
Grove Base Shield V2.0 for Arduino
You can check here for more info about the fun project!
Dimension(big one) 50 × 25 × 13 mm
Plane dimension(small one) 25 ×25 × 13 mm
Material ABS
Color Blue, green, yellow and red for both sizes for wrapper.
Different type of wrapper and corresponding SKU
Product name
Grove - Red Wrapper 1*1(4 PCS pack) 110070020
Grove - Yellow Wrapper 1*1(4 PCS pack) 110070021
Grove - Blue Wrapper 1*1(4 PCS pack) 110070022
Grove - Green Wrapper 1*1(4 PCS pack) 110070023
Grove - Red Wrapper 1*2(4 PCS pack) 110070024
Grove - Yellow Wrapper 1*2(4 PCS pack) 110070025
Grove - Blue Wrapper 1*2(4 PCS pack) 110070026
Grove - Green Wrapper 1*2(4 PCS pack) 110070027
r Lego, mechanical parts, and so on, this will introduce flavor into your work and make your project adapt to various circumstances. The mechanical design of Grove - Wrapper also make it easy to assemble and disassemble modules.
  • Flex fastener to install and replace Grove modules conveniently
  • Always keep your project safe
  • Half-open space, no disruption for using Grove modules
  • Compatible with Lego and Makeblock modules that will make your project adapting and interesting
  • Support being fastened with screws(M2, M4)
  • Mutual-connect-able like Lego modules does
  • Colorful wrappers
Product name
Dimensions 25mm x25mm x13mm
Weight G.W 25g
Battery Exclude
Material ABS
Grove - Green Wrapper 1*1 4
HSCODE 3926909090
USHSCODE 3926100000
UPC 841454118107
EUHSCODE 3926909705
COO CHINA
EU DoC 1
RoHS 1
UK DoC 1
Documentations
  1. Product Quality
    100%
    Documentation
    100%
    from order view
    Very good product and fast delivery. Well protected package. Highly recommended!
    By
  2. Product Quality
    100%
    Documentation
    100%
    from order view
    This user did not leave any comments
    By
  3. Product Quality
    80%
    By
3 Item(s)
Show per page
