Grove - Gas Sensor(MQ2) - Arduino Compatible
Fast response Adjustable sensitivity Covers LPG, i-butane, methane, alcohol, Hydrogen etc Useful for gas leakage detecting Grove connector compatible
- 10+: $6.60
Tip
We've released the Seeed Gas Sensor Selection Guide, it will help you choose the gas sensor that best suits your needs.
The Grove - Gas Sensor(MQ2) module is useful for gas leakage detecting(in home and industry). It can detect LPG, i-butane, methane, alcohol, Hydrogen, smoke and so on. Based on its fast response time. measurements can be taken as soon as possible. Also, the sensitivity can be adjusted by the potentiometer.
For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your using of the product.
Note
Hot-swapping the grove may lead to IC burnout, please turn off the power of the main board before swapping grove.
Wide detecting scope
Stable and long lifetime
Fast response and High sensitivity
Documents
More information about the gas sensor, please refer to this manual.
One More Thing
Dimensions | 130mm x90mm x32mm |
Weight | G.W 16g |
Grove - Gas Sensor(MQ2) | 1 |
Grove cable | 1 |
HSCODE | 9027900000 |
USHSCODE | 9026104000 |
UPC | 841454108351 |
EUHSCODE | 9013101000 |
COO | CHINA |
EU DoC | 1 |
RoHS | 1 |
UK DoC | 1 |
from order viewThis user did not leave any comments.
Nice
