Grove - GPS (Air530),GPS location, Long-distance communication
Grove-GPS (Air530) is a high-performance, highly integrated multi-mode satellite positioning and navigation module, supporting plenty of location systems, such as GPS/Beidou/Galileo and etc.
- 10+: $8.00
Feature
- Highly Integrated Multi-mode Satellite Positioning: Multi-mode satellite positioning & navigation and support more than 6 satellites at the same time
- High precision Positioning: Positioning error within 10 meters,and the position still quickly and accurately under the condition of bad signal
- The Integrated Design of RF Baseband: Adopt the integrated design of RF baseband, which integrates DC/DC, LDO, LNA, RF front-end, baseband processing, 32-bit RISC based chip, RAM, FLASH storage, RTC, and power management functions
- Low Power Consumption: Low power consumption at only 31uA
- High Compatibility: Compatible hard/soft interface for other modules
Confused about your GPS not working well in urban or outsides under only one or a few satellite module? Then you should not miss our new Grove-GPS (Air530). It’s a high-performance, highly integrated multi-mode satellite positioning and navigation module to use with Arduino. It supports GPS / Beidou / Glonass / Galileo / QZSS / SBAS, which makes it suitable for GNSS positioning applications such as car navigation, smart wear, and drone. Meanwhile, this module is capable of receiving more than 6 satellites at the same time and is able to work excellently even if there's a very bad signal.
Grove – GPS Module vs Grove – GPS (Air530)
Specs | Grove – GPS Module | Grove – GPS (Air530) |
Size | 40mm x 20mm x 13mm | 40mm x 20mm x 13mm |
Update Rate | 1Hz, max 10Hz | – |
Baud Rate | 9,600 – 115,200 | 9600 –921600 |
Navigation Sensitivity | -160dBm | –166dBm |
Power Requirements | 3.3/5V | 3.3/5V |
Number of Channels | 22 tracking, 66 channels | – |
Time to first start | Cold start: 13s Warm start: 1-2s Hot start: <1s |
Cold start: 30 seconds Warm Start: 4 seconds |
Antennas | Antenna included | Antenna included |
Accuracy | 2.5m GPS Horizontal Position Accuracy | 2.5m Horizontal positioning accuracy |
Specification
parameters | values | |
Supply voltage | 3.3V/5V | |
Working current | up to 60mA | |
Interface | UART | |
Time of warm start | 4s | |
Time of cold boot | 30s | |
Working Temperature | -35C-85°C | |
Storage Temperature | -55°C-100°C | |
Humidity | 5%-95% | |
Time of Positioning |
Pure hardware cold start | 27.5s |
Pure hardware hot start | <1S | |
Pure hardware recapture | <1S | |
Software-assisted A-GNSS | <5S | |
Sensitivity |
Cold start | -148dBm |
Hot Start | -162dBm | |
Recapture | -164dBm | |
Track | -166dBm | |
Accuracy |
Horizontal positioning accuracy | 2.5m |
High positioning accuracy | 3.5m | |
Speed accuracy | 0.1m/s | |
Time transfer accuracy | 30ns | |
Consumption |
Capture current [email protected] | 42.6mA |
Tracking current [email protected] | 36.7mA | |
Low power [email protected] | 0.85mA | |
Ultra-low-power [email protected] | 31uA |
Note
The test above is taken under bi-modules of GPS&Beidou.
Pinout
Applications
- GPS tracker
- GPS navigation
- Distance measurement
- Car navigation
- Drone
Part list
Items | Values |
GPS (Air 530) board | 1 |
Grove cable | 1 |
Cautions
- The input power supply voltage of Grove power supply interface, should not exceed 5.6V, otherwise it may damage the device.
- The voltage of the selected button battery should not exceed 3V, or it will probably damage the device.
HSCODE | 8526919090 |
USHSCODE | 9026104000 |
UPC | |
EUHSCODE | 9013101000 |
EU DoC | 1 |
RoHS | 1 |
UK DoC | 1 |
from order viewI like the device.
from order vieweverything is fine
from order viewOK, OK, OK, OK, OK, OK,
from order viewNeat idea. lots of applications.
from order viewIn general I like the Seeed products. They make it easier to tinker. It is hard to rate the shipping with current issues in world etc. as a bit slow but I did know it was it was out of stock up front. This particular shipment I got solely to run through the training / education on the seeed site.
- Page Previous
- Page 1
- Page 2
- You're currently reading page 3
- Page 4
- Page Next
