Grove Expansion - .NET Gadgeteer Compatible
This product can now be purchased at www
This product can now be purchased at www.ghielectronics.com.
Grove Expansion module for Gadgeteer. This module has 6 standard 4-pin Grove connectors, Those existing Grove modules that you want to use in Gadgeteer project can be connected to the Gadgeteer mainboard using this extension. Note that you will need to use or ref the drivers or Lib from the Grove page you are trying to use .
The socket type is depend on your require.
- Six 4-pin standard Grove connectors
- Socket type is depend on the Grove module that you are using
- A switch to select Grove voltage supply
For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your using of the product.
External Links
you need to download the following software to start your Gadgeteer:
- Development tool : Microsoft Visual C# Express 2010
- Micro framework: Microsoft .NET Micro Framework 4.1 SDK
- The Gadgeteer core, mainboard SDk and module driver(GHI)
You can download these tools at : http://tinyclr.com/support
Dimensions | 0mm x0mm x0mm |
Weight | G.W 10g |
HSCODE |
