Grove - Barometer Sensor(High-Accuracy): Measuring Barometric Pressure, Altimeter, and Temperature
This Grove - Barometer (High-Accuracy) Sensor features an HP206C high-accuracy chip to detect barometric pressure, Altimeter, and temperature. It can widely measure pressure ranging from 300mbar~1200mbar, with super high accuracy of 0.01mbar(0.1m) in ultra-high resolution mode.
- 10+: $16.40
- Three-in-one measurement: Barometric pressure, Altimeter, and temperature measurement included that measures the pressure and the temperature by an internal 24‐bit ADC and compensates them by a patented algorithm
- Wide barometric pressure range: Pressure measurements range from 300mbar~1200mbar
- High-accuracy: Altitude resolution down to 0.01 meter
- Digital two-wire (I2C) interface: High-speed I2C Digital Output Interface (Up to 10 MHz)
- Grove compatible interface: The product ensures "Plug and Play" and could be versatile for various applications of Grove
Grove - Barometer (High-Accuracy) Sensor features an HP206C high-accuracy chip to detect barometric pressure, Altimeter, and temperature. It can widely measure pressure ranging from 300mbar~1200mbar, with super high accuracy of 0.01mbar(0.1m) in ultra-high resolution mode. The chip only accepts 1.8V to 3.6V input voltage. However, with the outer circuit added, this module becomes compatible with 3.3V and 5V. Therefore, it can be used on Arduino/Seeeduino boards or Seeeduino Stalker without modification. It is designed to be connected directly to a microcontroller via the I2C bus.
What is Barometer
The barometer is a widely used weather instrument that measures atmospheric pressure (also known as air pressure or barometric pressure) -- the weight of the air in the atmosphere. It is one of the basic sensors included in weather stations. Barometers have evolved through the centuries and come in all shapes and sizes. It is also used in more industries than just the weather and climate sectors.
We have developed more than 400 Grove modules, covering a wide range of applications that can fulfil various needs. Click to explore the Grove Sensor family and get started to Grove your Idea. For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your use of the product.
Applications
- High Precision Mobile Altimeter / Barometer
- Industrial Pressure and Temperature Sensor System
- Automotive Systems
- Personal Electronics Altimetry
- Adventure and Sports watches
- Medical Gas Control System
- Weather Station Equipment
- Indoor Navigation and Map Assist
- Heating, Ventilation, Air Conditioning
One More Thing
Item | Min | Typical | Max | Unit |
Voltage | 3.3 | 5 | 5.5 | VDC |
Current | 635 | / | 1100 | uA |
Pressure Range | 300 | / | 1200 | hPa |
Faster I2C data transfer | / | / | 10 | MHz |
Dimension | 20.4*41.8*9.7 | mm | ||
Weight | / | g |
Grove - Barometer (High-Accuracy) | 1 |
Grove - cable | 1 |
HSCODE | 9026900090 |
USHSCODE | 9026104000 |
UPC | 841454108733 |
EUHSCODE | 9013101000 |
COO | CHINA |
EU DoC | 1 |
RoHS | 1 |
UK DoC | 1 |
