Grove - Line Finder v1.1
- 10+: $3.00
Most automated robotic projects start from a line-following robot, Grove - Line finder v1.1 is designed to achieve this task easily and quickly.
- Integrated function: An IR indicator LED and an IR-sensitive phototransistor
- Digital output: A digital signal will change from HIGH to LOW. High when black is detected, Low when white is detected
- Easy to use: Compatible with Grove port, just plug-and-play
- Flexible detection: The detecting range is adjustable
Grove-Line finder is designed for a line-following robot. It has an IR emitting LED and an IR-sensitive phototransistor. It can output a digital signal to a microcontroller so that the robot can follow a black line on a white background or vice versa.
Those eye-like sensors on the board are actually IR emitting LED and sensitive phototransistors. When the phototransistor detects the reflected infrared light from the IR emitting LED, it will output a digital signal, which changes from HIGH to LOW.
We have developed more than 400 Grove modules, covering a wide range of applications that can fulfill various needs. Click to explore the Grove Sensor family and get started to Grove your Idea. For all Grove users (especially beginners), we provide you with guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your use of the product.
Application
- Delivery Robotics
- Mini Toy Car
One More Thing
Specifications
Power supply | 5V DC |
Digital output mode | TTL (High when black is detected, Low when white is detected) |
Connector | 4-pin Buckled Grove interface |
Comparator | LMV358 |
Photo reflective diode | RS-06WD |
Dimension | 20mm*20mm |
Dimensions | 24.2mm x20mm x10.8mm |
Weight | G.W 8g |
Connector | 4 pin Buckled Grove interface |
Comparator | MV358 |
Grove - Line Finder v1.1 | 1 |
![](https://media-cdn.seeedstudio.com/media/wysiwyg/certification/EUDOC.png)
![](https://media-cdn.seeedstudio.com/media/wysiwyg/certification/ROHS.png)
![](https://media-cdn.seeedstudio.com/media/wysiwyg/certification/UKDOC.png)
HSCODE | 9031900090 |
USHSCODE | 8517180050 |
UPC | 841454118855 |
EUHSCODE | 9013101000 |
COO | CHINA |
from order viewExcellent product and documentation easy to use
