General Plastic Case 28x44x70 mm
This case is a general box for different uses
This case is a general box for different uses. It a simple and convenient case suitable for giving your sensors protection, classifying your little components and even building a DIY enclosure for your work!Here are some details about this case:
- Inner dimension: 25x40x66mm; Out dimension: 28x44x70mm; Thickness: 2mm
- Shallow gray, shiny surface and easy to close and open with your nails
- Made of plastic
Dimensions | 0mm x0mm x0mm |
Weight | G.W 22g |
HSCODE | 3923100090 |
