External Antenna for RF Explorer®️Pro; 4dBi 5G Rod Antenna-support 900MHz-6GHz
This is an external articulated antenna for all RF Explorer®️models, and a replacement for RF Explorer®️Pro stock antenna, supporting the frequency range of 900MHz-6GHz. You can order it as a replacement if your original antenna got damaged or lost, or as a backup antenna.
- 10+: $24.00
This antenna is perfect for use with all RF Explorer®️models in the 900MHz-6GHz frequency range, specially RF Explorer®️Pro and 6G Combo PLUS models. It is designed to provide a strong and effective antenna. It has a hinged structure and has better performance in vibration environment. And it is easy to install and requires no maintenance throughout its life cycle. The antenna provides independent ground plane omnidirectional performance, and its efficient element design ensures fast first-time connection rates and a consistently strong communication link, providing stable communication connections even in problematic coverage areas.
Key Features
- Powerful frequency band support: Supports 900MHz-6GHz frequency band.
- Sturdy and efficient design:Equipped with a hinged structure and solid ABS covering for better performance in vibration environments.
- Efficient signal connection quality: Provide independent ground plane omnidirectional performance, fast first connection rate and continuously strong communication link.
- Convenient and quick installation: Equipped with standard SMA connector, it can be quickly installed on the device.
- Authoritative certification: This product complies with RoHS certification and meets environmental protection requirements.
Specifications
Dimensions (mm) |
15*135*24 |
Net Weight (g) |
16 |
Connector |
SMA-Male |
Radome |
Black ABS |
Frequency Bands (MHz) |
698-960 |
1710-2690 |
5150-5850 |
VSMR Max |
7.0 : 1 |
3.0 : 1 |
3.0 : 1 |
Peak Gain, Typical (dBi) |
Up to 418 |
Nominal Impedance |
50Ω |
Max Power at 25℃ (W) |
10 |
Azimuth Beam Width (deg) |
Omnidirectional |
Polarization |
Linear, Omnidirectional |
Storage Temperature Range (℃) |
-40 to 85 |
Operational Temperature Range (℃) |
-40 to 85 |
Material Substance Compliance |
RoHS |
Hardware Overview
External Antenna for RF Explorer®️Pro |
x1 |
HSCODE | 9030900090 |
USHSCODE | 8517180050 |
UPC | |
EUHSCODE | 9030900000 |
COO | CHINA |
