Europe Standard USB Wall Power Supply 5VDC 2.1A - CE Intertek GS
- 10+: $6.26
This high quality AC to DC power supply is "wall wart" type, featuring short circuit protection, over current protection and efficient AC to DC conversion over 80%.
These have a standard USB ‘type A’ connector for the output so you can power your Raspberry Pi, Cubieboard, etc. through a USB cable. Any device that uses a USB cable for charging or power can be powered with this supply.
And, This version in accordance with European standard interface.
Feature:
Wall mount type
Short circuit protection
Over current protection
Conversion efficiency more than 80%
Compatible with Raspberry Pi A+,B,B+/2.
Specification:
Rated Input: 100-240V AC~50/60Hz 0.3A
Rated Output: 5V/2.1A
Connector: USB Female
Certifications: CE
Size: 5.5cm x 3cm
Dimensions | 0mm x0mm x0mm |
Weight | G.W 49g |
HSCODE | 8504409999 |
USHSCODE | 8504100000 |
UPC | 841454116271 |
EUHSCODE | 8504400000 |
COO | CHINA |
EU DoC | 1 |
RoHS | 1 |
UK DoC | 1 |
