Serial to Ethernet Module based on ESP32 series - WT32-ETH01
WT32-ETH01 is an embedded serial to Ethernet module based on the ESP32 series WT32-S1 MCU. The module integrates an optimized TCP/IP protocol stack, which is convenient for users to easily complete the networking functions of embedded devices while reducing development time cost. In addition, the module is compatible with half-pad and through-hole connectors. The board width is a universal width and therefore, it can be directly soldered to boards, connectors, or even breadboards, which is convenient for users to use in different scenarios.
- 10+: $15.30
- Support complete TCP/IP protocol stack
- Rich wireless communication interface
- Multiple working modes using through holes and half-pads
The ESP32 series of ICs are SOCs that integrate 2.4GHz Wi-Fi and Bluetooth dual-mode, with ultra-high radio frequency performance, stability, versatility, reliability, and ultra-low power consumption.
Specifications
Specification | Items | Details |
Wi-Fi | RF Certifications | FCC/CE/RoHS |
Protocols | 802.11 b/g/n/e/i(802.11n,Up to 150 Mbps) | |
A-MPDU and A-MSDU aggregation, 0.4_ s guard interval support | ||
Frequency range | 2.4~2.5 GHz | |
Bluetooth | Protocols | Bluetooth v4.2 BR/EDR and BLE standards |
Radio | NZIF receiver with -97 dBm sensitivity | |
Hardware | Network port specifications | RJ45, 10/100Mbps, Cross-direct connection adaptive |
Serial baud rate | 80~5000000 | |
On-board flash | 32Mbit | |
Operating voltage | 5V or 3.3V | |
Operating current | Average: 80mA | |
Supply current | Minimum: 500 mA | |
Operating temperature | -40°C~+85°C | |
Ambient temperature | Normal temperature | |
Packaging | Half pad/ Through-hole connector( Optional) | |
Software | Wi-Fi mode | Station/softAP/SoftAP+station/P2P |
Wi-Fi security mechanisms | WPA/WPA2/WPA2-Enterprise/WPS | |
Encryption types | AES/RSA/ECC/SHA | |
Firmware update | Remote OTA upgrade via network | |
Software development | SDK used for further development | |
Networking protocol | IPv4、TCP/UDP | |
IP access methods | Static IP、DHCP(Default) | |
Transparent transmission modes | TCP Server/TCP Client/UDP Server/UDP Client | |
User configurations | AT+ commands set |
Pinout Diagram
1 x Serial to Ethernet Module based on ESP32 series - WT32-ETH01
HSCODE | 8517709000 |
USHSCODE | 8517180050 |
UPC | |
EUHSCODE | 8517180000 |
COO | CHINA |
RoHS | 1 |
Documentations
from order viewexcellent item
