Electronic brick-Touch Sensor module
ELB142D2P
This is a simple touch sensor brick, it used TTP223 touch detector IC, you can use this brick to replace the traditional physical push button, add some cool element to your project
This is a simple touch sensor brick, it used TTP223 touch detector IC, you can use this brick to replace the traditional physical push button, add some cool element to your project.
Dimensions | 0mm x0mm x0mm |
Weight | G.W 3.5g |
