Digital Storage Oscilloscope DIY Kit with Panels
TOL107C3M
Read this first:Before you buy this KIT, make sure you have enough DIY ability to finish it
Read this first:
Before you buy this KIT, make sure you have enough DIY ability to finish it. We will provide as much help as we can if you need, but we won't guarantee the replacement unless the problem is caused by failure parts.
Assembled view
Kit includes:
1 ) All parts (excluding power adapter)
2 ) Schematic
3 ) Assembly Notes
4 ) Operatiing instructions
5 ) MCU (ATmega64) has been pre-soldered and programmed
[ Note: SMD soldering skills are required for 06201KP. Fortunately there are plenty of sites that teach these skills. Simply search with "SMD soldering" you will find lots of them. ]
Dimensions | 0mm x0mm x0mm |
Weight | G.W 80g |
