Desktop 3D printer G1000 (1000*1000*1000mm)
Product Feature: The G1000 3D Desktop Printer is our most popular 3D printers where it can be used for personal interest projects all the way to prototypes for commercial projects by providing an easy to use and reliable prototyping experience.
If you would like to purchase or obtain more information about this item, please email us at: [email protected]
• The G1000 3D Desktop Printer is our most popular 3D printers where it can be used for personal interest projects all the way to prototypes for commercial projects by providing an easy to use and reliable prototyping experience.
• G1000 also facilitates with Cura, the open-source 3D printing software, allowing 3D models to be printed out using 3D printers with ease. On top of that, Cura has built a large user community which are very useful for frontend support.
Product Features:
• Moulding Method: FDM
• Software Language: English/Chinese
• LCD Screen: Full Colour Touch Screen
• Printing Precision(mm): 0.05-0.2
• Moulding Size(mm): 1000*1000*1000
• Layer Thickness(mm): 0.05-0.2
• Nozzle Temperature: 0-235℃
• Moving Speed: 200-500mm/s
• Positioning Precision(mm): X/Y axis: 11μ; Z axis: 2.5μ
• Build Plate Temperature: Professional build plates do not require heating
• Filaments: PLA/ABS
• Input Voltage/Frequency/Current/Power: 220V, 50-60HZ, 5.4A/2.2A, 350W
• Filament Diameter(mm): 1.75
• Interface Type: USB/SD Card
• Frame: Metal
• Operator Interface: LCD
• File Format: STL/OBJ
• Environment: Temperature: 15-32℃, Humidity 20-50%
• Quality Certificates: CE,FCC,ROHS
TECHNICAL PARAMETERS
Moulding Method
FDM |
Software Language
English/Chinese
LCD Screen
Full colour touch screen
0.05-0.2
Moulding Size(mm)
1000*1000*1000mm
Layer Thickness(mm)
0.05-0.2
Nozzle Temperature
0-235℃ |
Move Speed
200-500mm/s
Positioning Preceision(mm)
X/Y axis 11μ; Z axis 2.5μ
Professional plate without heating
Packing size
760x305x315 mm
Filaments | PLA/ABS |
Filament Diameter(mm) | 1.75 |
Input Voltage/Frequency/Currency/Power | 220V, 50-60HZ,5.4A/2.2A, 350W |
Interface Type | USB/SD Card |
Frame | Metal |
Operator Interface | LCD |
File Format | STL/OBJ |
Environment Temperature | 15-32℃,Humidity 20-50% |
Quality Certificates | CE,FCC,ROHS |
