DVK570 Shield for Cubietruck
DVK570 is an expansion board designed for Cubietruck, integrates various components and interfaces for connecting external accessory boards
- 10+: $26.55
DVK570 is an expansion board designed for Cubietruck, integrates various components and interfaces for connecting external accessory boards. It's ideal for Cubietruck evaluation and development.
SPECIFICATION
Cubietruck connector
UART0 interface: for connecting serial debugging module
I2C interface: easily connects to I2C modules such as PCF8563 RTC Module, MAG3110 Board, etc.
TVIN interface: video input
TVOUT interface: video CVBS output, for connecting display devices like TV
LINEIN interface: audio input
USB interface: USB TO UART (PL2303TA)
UART interface: easily connects to UART modules such as RS485 Board (3.3V), GPS module, etc.
SPI interface: easily connects to SPI modules such as AT45DBXX Dataflash, etc.
ZigBee connector: for connecting ZigBee modules like Core2530, supports working with ZB501
ONE-WIRE interface: easily connects to ONE-WIRE devices (TO-92 package), such as temperature sensor (DS18B20), electronic registration number (DS2401), etc.
12.5V/3.3 V power input/output: usually used as power output, also common-grounding with other user board
PL2303TA: onboard USB TO UART convertor
12M crystal: for PL2303TA
Buzzer
User LEDs: 4 colorful LEDs
Power indicator
AD keys: 7 common Android keys
ONE-WIRE jumper
Buzzer jumper
AD Keysjumper
User LEDs jumper
TVIN jumper
TVOUT jumper
UART0 jumper
For jumpers above:
- • short the jumper to connect to I/Os used in example code
- • open the jumper to connect to other custom pins via jumper wires
PART LIST
• 1x DVK 570 board
Dimensions | 160mm x175mm x20mm |
Weight | G.W 62g |
HSCODE | 8517709000 |
UPC | 841454110170 |
COO | CHINA |
