Crazyflie 2.0 - Spare 240mAh LiPo battery
Small high performance spare battery for the Crazyflie 2,bitcraze, bitcraze.io,crazyfly, crazieflie, crazieflie, crazy flie, crazie fly, crazy fly, drone
Small high performance spare battery for the Crazyflie 2.0
Operating Temperature: 0 ~35°C (Charging) / -20~60°C (Discharging)
Connector: Molex 51005-2P (Pin 1 positive)
Electrical specification
Capacity: 240mAh
Nominal voltage: 3.7 V (1 Cell)
Discharge: 15C
Charge: 2C
Mechanical specification:
Weight: 7.1g
Size (WxHxD): 20x7x30mm
Caution
Using the battery under direct sunlight may cause overheating, which could result in invalidation or fire. Battery should be charged with proper charger, in compliance with correct operation instruction.
Tech Support
If you have any further question for technical support, please contact [email protected]
Dimensions | 0mm x0mm x0mm |
Weight | G.W 7g |
Battery | Lithium Cells / Batteries loose (bulk) UN3480-PI965 |
240mAh LiPo battery | 1 |
HSCODE | 8507600090 |
ROHS | 1 |
