Clear Plastic Enclosure 55x90x115mm
You project looks like a mess? Are you ready to get it a neat and beautiful enclosure? We are excited to tell you that nine kinds of project boxes are on the shelf now! They have different sizes and colors, to make sure you can find one that matches your
You project looks like a mess? Are you ready to get it a neat and beautiful enclosure? We are excited to tell you that nine kinds of project boxes are on the shelf now! They have different sizes and colors, to make sure you can find one that matches your project 100%. Here are some details about the one you saw above:
- Inner dimension: 49x84x109mm; Out dimension: 55x90x115mm; Thickness: 3mm; Upper cover Thickness: 4mm. Screw hole outer radius R=6mm
- Made of plastic, thick and durable
- Including a clear upper case, a gray button case, 4 screws and a piece of elastic cord to fix parts
- 4 holes for you to fix the top cover and the button cover with Nickel screws.
- Waterproof when fixed by screws
Dimensions | 0mm x0mm x0mm |
Weight | G.W 150g |
HSCODE |
