Clear Plastic Enclosure 55x145x222 mm
Another upgraded version! This one is a big brother of the HF-H-3T
Another upgraded version! This one is a big brother of the HF-H-3T. With a wider crystal upper cover and large capacity, it’s absolutely big enough to hold a waterproof project even with a display screen. Here are some details about this case.
- Inner dimension: 48x140x215mm; Out dimension: 55x145x222mm; Thickness:3mm; Upper cover Thickness: 4mm, Screw hole outer radius: R=6mm
- Color: a crystal upper case and a gray button case
- Including 6 screws to fix the upper and the button and one piece of elastic cord maybe you will need in case of tying something up
- Made of plastic, durable and easy to drill or shape
- Water proof
Dimensions | 0mm x0mm x0mm |
Weight | G.W 350g |
HSCODE | 3923100090 |
