CO2 monitoring with WioTerminal
This kit provides the components needed to implement a CO2 monitoring system using WioTerminal. Including WioTermianl, Grove-SCD30, Grove cable,etc. This system can continuously measure indoor air quality and remind the room to ventilate.
This kit provides the components needed to implement a CO2 monitoring system using WioTerminal and CO2 sensors. This is a simple IoT project, which uses components including WioTermianl, Grove-SCD30, Grove cableetc. This system can continuously measure indoor air quality and remind the room to ventilate, which is an item related to people's health.
KeHoSoftware provides us with a tutorial for implementing a CO2 monitoring system using WioTerminal and CO2 sensor. The system uses Wio terminal to connect CO2 Grove-CO2 & Temperature & Humidity Sensor for Arduino (SCD30). The data can be visualized from the display screen of the Wio terminal. If the CO2 concentration parameter reaches an unsatisfactory level, a reminder will be generated telling you to open the window for ventilation.
Before officially starting this project, you should prepare the listed WioTerminal, GroveGrove-CO2 & Temperature & Humidity Sensor for Arduino (SCD30), Grove cable, etc. After preparing these things, we can start to build our CO2 monitoring system!
The main process includes collecting the hardware, adding external libraries to compile the code correctly, configuring the Android mobile application, debugging and running. For specific operations, please refer to CO2 monitoring with WioTerminal.
Monitoring data visualization-real-time display on WioTerminal
IoT-based air quality solution-carbon dioxide CO2
Application
CO2 air quality monitoring
Documentations
CO2 monitoring with WioTerminal- Credits to KeHoSoftware
