Bus Pirate v3.6 acrylic case v1 (DP6037)
A clear laser-cut acrylic case kit for the Bus Pirate v3
- 10+: $2.70
A clear laser-cut acrylic case kit for the Bus Pirate v3.6. This case is designed to be simple, cheap, and easy to assemble. The Bus Pirate PCB is sandwiched between two laser-cut acrylic sheets, and the whole assembly is held together with aluminum screws and standoffs.
This is only compatible with Bus Pirate v3.6 that uses a DP6037 standard PCB template.
If you encounter any problems when using this product, here is the forum from which you can get the technical support.
Dimensions | 0mm x0mm x0mm |
Weight | G.W 26g |
HSCODE | 3926909090 |
USHSCODE | 3926100000 |
UPC | 841454111184 |
EUHSCODE | 3926909705 |
COO | CHINA |
RoHS | 1 |
Well made. Easy to assemble.
Good enclosure
Not compatible with the SOIC Version
