Bus Blaster v3 acrylic case v1 (SoBv1-DP8049)
A clear laser-cut acrylic case kit for the Bus Blaster v3
A clear laser-cut acrylic case kit for the Bus Blaster v3. This case is designed to be simple, cheap, and easy to assemble. The Bus Blaster PCB is sandwiched between two laser-cut acrylic sheets, and the whole assembly is held together with aluminum screws and standoffs.
This is only compatible with Bus Blaster.V3 that uses a DP8049 standard PCB template.
DOES NOT WORK WITH CURRENT Bus Blaster V2 or V2.5!
- Homepage
- Eagle PCB template library
- Assembly instructions
- Sick of Beige PCB sizes and specifications
If you encounter any problems when using this product, here is the forum from which you can get the technical support.
Dimensions | 120mm x85mm x11mm |
Weight | G.W 37g |
HSCODE | 3926909090 |
USHSCODE | 3926100000 |
UPC | 841454111252 |
EUHSCODE | 3926909705 |
COO | CHINA |
RoHS | 1 |
