BeagleBone®
The BeagleBone® is the low-cost, high-expansion focused BeagleBoard using a low cost AM335x Cortex A8 ARM processor
The BeagleBone® is the low-cost, high-expansion focused BeagleBoard using a low cost AM335x Cortex A8 ARM processor. It is similar to the earlier BeagleBoards and can act as a USB or Ethernet connected expansion companion for your current BeagleBoard and BeagleBoard-xM or work stand-alone. The BeagleBone® is small even by BeagleBoard standards and with the high-performance ARM capabilities you expect from a BeagleBoard, the BeagleBone® brings full-featured Linux to places it has never gone before.
Pack list
- Latest version BeagleBone® A6
- 4GB microSD card with image files in case of damage on the card
- USB programming cable
- MicroSD adapter
More info, please click here.
If you encounter any problems when using this product, here is the contact from which you can get the technical support.
Dimensions | 0mm x0mm x0mm |
Weight | G.W 75g |
HSCODE |
