Argon ONE M.2 Aluminum Case for Raspberry Pi 4 - With SSD support via M.2, Two Full-Sized HDMI, Power Button, Cooling Fan & IR Support
Argon ONE M.2 is a Raspberry Pi 4 compatible case that is made with aluminum alloy and polished with a modern Space Grey finish for stunning aesthetics and functionality. It has a 30mm software-controllable fan and air vents for better cooling. Also, you can connect an SSD via the m.2 connector and therefore supports high-speed data transfers. This case has two full-sized HDMI ports and also has a built-in power button for safe shutdowns, reboots, and forced shutdowns. Furthermore, it has two power management modes and has programmable IR support.
- 10+: $40.00
Product Details
Wiki & Learn
Reviews
