Arduino Starter Kit
- 2+: $83.00
- 50+: $79.00
This product is retired, please consider our ARDX - The starter kit for Arduino as your alternative choice.
ARDX – The starter kit for Arduino is the latest Arduino starter kit produced by Seeed, it has been optimized a lot comparing to Arduino Starter Kit, including replacing components with more sensors, totally new illustrated guide and 13 project circuit that make you start immediately. It is a really good choice if you are finding Arduino Starter Kit for beginners, even for kids.
Here is The Arduino Starter Kit!
This kit walks you through the basics of using the Arduino in a hands-on way. You'll learn through building several creative projects. The kit includes a selection of the most common and useful electronic components with a book of 15 projects. Starting the basics of electronics, to more complex projects, the kit will help you control the physical world with sensor and actuators.
The projects in the kit are:
GET TO KNOW YOUR TOOLS an introduction to the concepts you'll need to use this kit
SPACESHIP INTERFACE design to control panel for your startship
LOVE-O-METER measure how hot-blooded you are
COLOR MIXING LAMP produce any color with a lamp that uses light as an input
MOOD CUE clue people in to how you're doing
LIGHT THEREMIN create a musical instrument you play by waving your hands
KEYBOARD INSTRUMENT play music and make some noise with this keyboard
DIGITAL HOURGLASS a light-up hourglass that can stop you from working too much
MOTORIZED PINWHEEL a color wheel that will have your head spinning
ZOETROPE create a mechanical animation you can play forward or reverse
CRYSTAL BALL a mystical tour to answer all your tough question
KNOCK LOCK tap out the secret code to open the door
TOUCHY-FEEL LAMP a lamp that responds to your touch
TWEAK THE ARDUINO LOGO control your personal computer from your Arduino
HACKING BUTTONS create a master control for all your devices!
Once you’ve mastered this knowledge, you’ll have a palette of software and circuits that you can use to create something beautiful, and make someone smile with what you invent.
Then build it, hack it and share it. Because Arduino is you!
(click on the name of the component to download the datasheet of the part).
1x Arduino Projects Book (170 pages)
1x Arduino UNO board rev.3
1x USB cable
1x Breadboard
1x Easy-to-assemble wooden base
70x Solid core jumper wires
2x Stranded jumper wires
10x Pushbuttons
1x Tilt sensor
1x LED (RGB)
8x LEDs (red)
8x LEDs (green)
3x LEDs (blue)
1x Small servo motor
3x Transparent gels (red, green, blue)
Look The Arduino Starter Kit gallery.
If you need support, please, visit the dedicated area in the Arduino forum section.
技術詳細
寸法 | 0mm x0mm x0mm |
重さ | GW 849g |
バッテリー | なし |
HSCODE |
ROHS | 1 |
