Aluminum Case Black - 163*106*55 (mm)
It is a reassemble-able aluminum case with oxidized surface, using 8 screws to assemble
It is a reassemble-able aluminum case with oxidized surface, using 8 screws to assemble. It will fit anything smaller than the size of 160*95.5*50.5, for example a hard drive. The solid material will protect its contents from bumping or accidental dropping.
- Easy assembling/disassembling
- Consist of 4 aluminum parts and 8 screws
- Firm and reliable
Specifications
- Material: Aluminum
- Color: Black
- External dimensions: 163*106*55 (mm)
- Inner dimensions: 160*95.5*50.5(mm)
- Waterproof: No
- All screws included
Dimensions | 0mm x0mm x0mm |
Weight | G.W 447g |
HSCODE | 7616991090 |
