K
Loading...
Aluminum Alloy CNC Heat Sink with Fan for Raspberry Pi CM4 Module
Rating:
100 % of 100
This is an aluminum alloy heat sink that is suitable to use with the Raspberry Pi Compute Module 4. It provides better heat dissipation through passive cooling while protecting the compute module. Also, it provides faster cooling through active cooling using a PWM fan. The speed of the fan can be easily controlled using a Python script provided. It is very easy to install and provides a good contact surface between the onboard components and the heat sink with the use of the included thermal pads.
$12.98
In stock
Product Details
Wiki & Learn
Reviews
