Air602 WiFi Module
Air602 WiFi Module
Note
Seeed fusion offers PCB/ PCBA manufacturing service for customized products based on Air602 WiFi Module with an online instant quote and fast delivery. Furthermore, business users can enjoy a free prototype and engineer support as well. Click here to learn more!
The Air602 is a 2.4G Wi-Fi module based on the embedded Wi-Fi SoC chip (W600) with a 12-pin Stamp Hole Expansion Interface. Miracly, it is even smaller than a stamp. It's only 12mm*10mm, small but complete, it offers a rich interface and complete functionality. This module support IEEE802.11b/g/n and AT command.
We also provide a USB+Antenna Board for this module, you can check Air602 WiFi Development Board .
Note
The Air602 forum is available now, you can find more resource here, and you can leave a message or discuss here
Interface
• Stamp Hole Expansion Interface, pin spacing 2.0mm
• Two UART, support RTS/CTS
• One SPI device controller
• Integrated GPIO device controller
Wireless
• Support IEEE802.11 b/g/e/i/d/k/r/s/w/n
• Support 2.4~2.4835 GHz
• Support Wi-Fi WMM/WMM-PS/WPA/WPA2/WPS
• Support Wi-Fi Direct
• STBC、GreenField、Short-GI
Others
• Support multiple network protocols: TCP/UDP/ICMP/DHCP/DNS/HTTP
Typical Applications
intelligent home appliances
smart home
wireless audio and video
smart toys
medical monitoring
industrial control
other Internet of Things applications.
Pin Map
External antenna recommendation
Chip Function Block Diagram
Dimensions | 12mm x10mm x1.2mm |
Weight | G.W 0.3g |
WiFi Mode | IEEE802.11b/g/n |
RF System Impedance | 50Ω |
SWR | <-10dB |
Frequency Range | 2.4~2.4835 GHz |
Physical Layer Data Rate | .11n MCS 0~7 150Mbps |
Modulation | DSSS、OFDM、DBPSK、DQPSK、CCK、QAM16/64 |
Output Power | IEEE802.11b, DSSS 1Mbps, POUT = +17dBm;IEEE802.11g, OFDM 54Mbps, POUT = +10dBm;IEEE802.11n, OFDM MCS7, POUT = +10dBm; |
Antenna Interface | Stamp Hole Expansion Interface |
Interface | UART、SPI、GPIO |
Interface Rate | 2Mbps@UART (Max); 50Mbps@SPI (Max) |
Operating Voltage | 3.3V |
Operating Current | 110mA(PS Mode 35mA,DTIM = 1) |
Operating Temperature | -40~+85℃ |
storage Temperature | -40~+125 ℃ |
Operating Humidity | 5%~90%RH |
Network Type | STA/AP/AP+STA/Wi-Fi Direct |
Verification Method | WEP/WPA-PSK/WPA2-PSK |
Encryption | WEP64/WEP128/TKIP/CCMP(AES) |
Network Protocol | TCP/UDP/ARP/ICMP/DHCP/DNS/HTTP |
Interface Protocol | AT+ instruction set |
IC | W600 Wi-Fi SoC |
Air602 WiFi Module | 1 |
HSCODE | 8517709000 |
USHSCODE | 8517180050 |
EUHSCODE | 8517180000 |
COO | CHINA |
RoHS | 1 |
