Air602 WiFi Development Board
The Air602 WiFi Development Board is based on Air602 Wi-Fi module and integrated USB interface and Antenna. If you plug this board into your computer, it will be recognized as an Ports (COM & LPT), so that you can code it with Serial port tool. This module support IEEE802.11b/g/n and AT command.
Meanwhile, if you do not need the USB, you can consider the Air602 Wi-Fi module. The size of which is only 12mm*10mm.
Note
The Air602 forum is available now, you can find more resource here, and you can leave a message or discuss here.
Interface
• USB interface
• UART/SPI
• Integrated GPIO device controller
Wireless
• Support IEEE802.11 b/g/e/i/d/k/r/s/w/n
• Support 2.4~2.4835 GHz
• Support Wi-Fi WMM/WMM-PS/WPA/WPA2/WPS
• Support Wi-Fi Direct
• STBC、GreenField、Short-GI
• Support multiple network protocols: TCP/UDP/ICMP/DHCP/DNS/HTTP
Typical Applications
intelligent home appliances
smart home
wireless audio and video
smart toys
medical monitoring
industrial control
other Internet of Things applications
PIN MAP
Chip Function Block Diagram
Dimensions | 3.8mm x1.5mm x3mm |
Weight | G.W 2g |
WiFi Mode | IEEE802.11b/g/n |
Frequency Range | 2.4~2.4835 GHz |
Modulation | DSSS、OFDM、DBPSK、DQPSK、CCK、QAM16/64 |
Interface | UART、SPI、GPIO |
Network Type | STA/AP/AP+STA/Wi-Fi Direct |
Verification Method | WEP/WPA-PSK/WPA2-PSK |
Network Protocol | TCP/UDP/ARP/ICMP/DHCP/DNS/HTTP |
Interface Protocol | AT+ instruction set |
IC | W600 Wi-Fi SoC |
Air602 WiFi Development Board | 1 |
HSCODE | 8517709000 |
USHSCODE | 8517180050 |
UPC | 841454121107 |
EUHSCODE | 8517180000 |
COO | CHINA |
RoHS | 1 |
Documentations
from order viewThis user did not leave any comments.
from order viewHaving trouble getting started with this one. Documentation could use more work. It's discontinued now, which probably explains it.
