Adjustable DC&DC Power Converter with LED segment display(4.5V - 28V&1.5A)
- 10+: $6.75
- 20+: $6.38
- More
- 50+: $6.00
- Less
Function
Operating mode description
With key off function, and reduce power consumption.
Power state can be freely defined
Input and output voltages can be displayed alternately
On/0ff output status, high level means output off, low level means output on. (note: high level (3.3v), the maximum output current 5mA)
Output voltage mode:Boot default display it, LED indicator off
Input voltage mode:Press button switch to it , LED indicator on
Alternating mode:Press button again input/output voltage alternately display (3s). Press button again, switch to output voltage display
Features:
In+: Input positive
In-: Input negative
Out+: Output positive
Out-: Output negative
weight: 20g
Dimensions: 62 *26 *14mm(length*width*height)
Ripple peak: About 100mV
Display color: Red/Green/Blue
Input voltage: 4.5-28V
Output power: 15W maximum
Output voltage: 1.3v-25v (step-down mode, the input voltage must be 2v higher than the output voltage)
Output current: 1.5A
Ripple frequency: About 150KHZ
Voltage meter accuracy: ±(5 ‰ +1 digit)
Static power consumption: Typical about 20mA
Stop working mode
Keep pressing the button until the monitor does not display numbers ( long press more than 4s) and release the button. LED lights and module shuts down. The output voltage is zero. At this time, it does not perform memory function. ON / OFF output high level (3.3V), then the static power consumption is about 2mA. Click the button, the module starts working again.
Dimensions | 0mm x0mm x0mm |
Weight | G.W 18g |
HSCODE | 8504901900 |
