Acrylic Case for Jetson Nano B01 with Cooling Fan, Dual Antenna Mounts, Power/FR/RESET Buttons
This is a transparent acrylic case that can provide protection for your Jetson Nano. It has an internal cooling fan to provide better heat dissipation when you use your Jetson Nano for more demanding tasks. Also, the dual antenna mounts allow you to install additional external antennas to experience better wireless signal strength. However, these antennas are not included in the package. The case comes with three additional buttons that can be used to power, reset and factory reset your Jetson Nano very easily. There are two camera holders on top of the case, and you can connect cameras that are supported by Jetson Nano to realize machine vision projects. Also, you can easily access the Jetson Nano GPIO using the side openings of this case.
- 10+: $12.00
