Temperature-Humidity Sensor-AF5485 (Encased RS485 )
The AF5485 is a high performance industrial network-based temperature and humidity transmitter. It measures the temperature and humidity environment in the form of digital display on the local display. When the measured data exceeds the limitation, the output control signal generate a sound alarm signal, at the same time the response is sent by the host command, to upload the data to the host through the RS485 bus in the data packets.
- 10+: $45.90
Product Details
Wiki & Learn
Reviews
