the AI Hardware Partner
Toggle Nav
Loading...
5 inch Capacitive touch screen & Acrylic Case Kit
Raspberry pi display, display, capacitive touch, touchscreen
$85.00
Out of stock
  • 10+: $80.00
This package contains a 5 inch screen and a set of acrylic shell. This is a very beautiful display suite, you can make it as your second monitor computer or with the use of the raspberry pi. 5 inch capacitive screen is very powerful, it is driver freer and support multi touch even the maximum support 10 point touch. It has a very good performance in the windows platform and for Linux and for Mac are also very good. Even without the touch screen calibration, all you need to do is plug and play. Only need to adjust the resolution in accordance with the actual needs when you are using Raspberry Pi.
• Easy to assemble
• Driver free
• Multi point touch
• Capacitive touch screen
• Compatible with Linux/windows/Mac
If you are willing to know more information about Raspberry Pi display, please view the table as follow.
Product nameResolutionPower supplyDisplay interfaceFor use withDimension(mm)Touch panel typeDisplay tec.
5 inch 720x1280 HDMI IPS LCD Display 720x1280 5V HDMI2.0 Raspberry Pi3, Windows, etc. 134x84 None IPS
5 inch 800x480 Capacitive TouchScreen 800x480 5V HDMI & USB 2.0 Raspberry Pi3, Windows, etc. 184x106x45 Capacitive TFT
5 Inch HDMI Display with USB TouchScreen 800x480 5V HDMI & USB 2.0 Raspberry Pi3, Pi4, Windows, etc. 170x90x40 Resistive TFT
5 inch Capacitive touch screen & Acrylic Case Kit 800x480 5V HDMI & USB 2.0 Raspberry Pi3, Windows, etc. 210x150x50 Capacitive TFT
7 inch 720x1280 HDMI IPS LCD Display 720x1280 5V HDMI2.0 Raspberry Pi3, Pi4, Windows, etc. 192x118 None IPS
Raspberry Pi 7 inch Touchscreen Display 800x480 5V Display ribbon cable Raspberry Pi3, Pi2, Pi 194x110x20 Capacitive TFT
7 Inch 1024x600 Capacitive Touch Screen With Camera Kit 1024x600 5V HDMI & USB 2.0 Raspberry Pi3, Windows, etc. 177x113x15 Capacitive TFT
10.1 inch 1200x1920 HDMI IPS LCD Display 1200x1920 5V HDMI2.0 Raspberry Pi3, Pi4,Windows,etc. 255x165 None IPS
15.6 Inch 1920*1080 Full HD IPS Touch Screen Portable Monitor 1920x1080 5V Mini DP/ Mini HDMI / Type C Raspberry Pi3,Pi4,Windows,etc. 375x230x12 Capacitive IPS
7 Inch HDMI 1280x800 IPS Display 1280x800 7.5V~12V AV + VGA + HDMI (HDMI 1.2) Raspberry Pi3, Windows, etc. 162x106x5 None IPS
7 Inch 1024x600 Capacitive Touch Screen DIY Kit 1024x600 5V AV + VGA + HDMI (HDMI 1.2) Raspberry Pi3, Windows, etc. 265x165x50 Capacitive TFT
10.1 Inch LCD Display - 1366x768 HDMI&VGA&NTSC&PAL 1366x768 5V~24V AV + VGA + HDMI (HDMI 1.2) Raspberry Pi3,Pi4,Windows,etc. 230x150x5 None TFT
Raspberry Pi HDMI LCD (10.1 inch) 1280x800 5V HDMI & USB 2.0 Raspberry Pi3,Pi4,Windows,etc. 290x200x35 Capacitive IPS
Dimensions 210mm x150mm x50mm
Weight G.W 350g
Battery Exclude
Power 5V Power via USB Micro
Current Max 500mA
Display Type 5 inch TFT LCD
Resolution 800x480
Touchscreen USB capacitive
Touch points 10 points maximum
Interface HDMI & USB 2.0 Full Speed
5 inch Capacitive Touch Screen 1
Acrylic Case Kit 1
30cm High Quality HDMI cable wire 1
MicroUSB Cable wire 1
HSCODE 8528521200
USHSCODE 8531809051
EUHSCODE 8531202090
COO CHINA
