3V LED Panel
KIT02244P
3V LED Panel is the extension pack for 3V Hexagon LED Panel Kit
3V LED Panel is the extension pack for 3V Hexagon LED Panel Kit. It's designed for the abecedarian to learn how to solder and also for who want to make colorful LED design.
It's a simple hexagon LED Panel and it is easy for you to solder the various color LEDs on it. Several panels can be connect together to compose a large LED panel, and the two panels can be connected firmly just by soldering two LEDs between them. The Panel supports 3V LEDs like green, blue, purple or white. It is different from the 2V LED Panel.
It includes one red hexagon PCB, 27pcs green LEDs and some electron components. With this pack, you can connect the PCB and design your own shinning LED Panel in different style.
Dimensions | 0mm x0mm x0mm |
Weight | G.W 12g |
